my baby still wont run
Old Aug 2, 2004 | 08:52 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Transmission: TKO-600 5 speed
Axle/Gears: 3.73 10 bolt
Heres the play by play:
I was driving along one day and all of a sudden i just hear it backfire a couple times and the engine starts stumbling.
Now when i start it up it runs pretty descent not perfect but descent. You can drive it to the end of the street and back once or twice and then it starts stumbling and backfiring. It will still idle but you cant give it any gas.
Let the car cool down for 24 hours and you can do it all over again.
Ive already replaced the dist module, ignition coil, o2 sensor (replaced that cause i found the wire was crispered), and i know my alternator and battery are both fine.
The car is not giving any codes either.
Any ideas?
Old Aug 3, 2004 | 08:13 AM
kevinc's Avatar
Car: 1982 Z28
Check your fuel pressure with the engine running and report back.
Old Aug 3, 2004 | 10:26 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
could be vapor locking ??? do you have headers on it ??
Old Aug 11, 2004 | 09:01 PM
19doug90's Avatar
Car: 1990 Camaro
Engine: 355ci
Fuel pressure is at 42 which is a bit high i believe but the car is getting flooded with gas the computer is compensating for something.
I can also say for sure its not dropping cylinders because i know how to listen for that in the exhaust.
My theory for why i have to drive it to the end of the street and back before it starts backfiring and such is it takes a minute for the car to go into limp home mode.
So before it goes into limp home mode its just flooding the car with gas. I'm thinking its something distributor related although i know its not the distributor module.
I also have a new 02 sensor that i replaced after the problem started so its nothing to do with that and im getting no codes.
Ideas?
Old Aug 12, 2004 | 11:17 PM
ghettocruiser's Avatar
Car: 86 Trans AM
Engine: LS1 (not stock...)
Transmission: Built T56
Axle/Gears: Strange 12-bolt w/ 3.73
Just a shot in the dark here...but did you try unplugging the MAF then taking her for a drive? My 87 TA had similar problems. No check engine light, only a year old MAF. I unhooked it and she ran like a raped ape again. Swapped it out, all is well. Give it a try if you dont think of something else. I have actually had two MAFs go out on me with no check engine light...and the light works. Good luck.
Justin
eightsixseven
Dec 16, 2024 01:50 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
Fast355
Dec 2, 2016 06:33 PM
perZ
Aug 21, 2015 05:51 PM
ezobens
Aug 19, 2015 10:29 PM
