Ignition timing???
Old Aug 2, 2004 | 09:16 PM
BAD91CamaroRS's Avatar
Car: 91 Camaro RS 383
Engine: carbed 383
Axle/Gears: 3.42 posi
Ignition timing???
OK I was wondering if someone could tell me what my timing should be at...The engine is a 350 bored out to 360, Performer RPM heads and intake, 600 cfm carb, 10:1 compression ratio, HEI ignition, i cant seem to find my cam specs which is really slowing me down but i know its a little over stock...I just turned 17 so im no expert by any means so any help is appreciated... ill try and see if i can get my cam specs...Brian
Old Aug 3, 2004 | 07:37 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
Axle/Gears: 9 bolt 3.27 posi
start at 10*advanced with the vaccum advance plugged and about 650 rpm if you can get it,you want about 34-36*@3000 rpmfor a total advance curve.adjust mechanical springs to get that,then adjust static advance til you get no detonation(rattle) climbing a hill in low gear,that should put you close.
Eric
Old Aug 3, 2004 | 07:39 AM
SLEEPER 86's Avatar
Car: 86 coupe
Engine: 383
oh yeah,plug the vaccum advance back in before you go for a test drive!
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
Bryan F
Aug 18, 2015 02:28 PM
