Loss of fuel pressure
Old Aug 2, 2004 | 09:22 PM
Hawk92z-TDZ's Avatar
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
Put the guage on tonight and I still run normal at 50psi but WOT is down to 30psi :shock: Plus I got NO fuel presure when it prime's and soon as I shut off the car, it go's straight to 0 too.
Now I just got to figure out what is causeing my loss in fuel presure. I got a funny feeling its the pump itself :? Not sure what else can cause this. Any guesses?
Fuel filter is only about 3000miles old.
Old Aug 3, 2004 | 09:32 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Sounds like it's fuel pump time.
Old Aug 3, 2004 | 09:55 AM
kevinc's Avatar
Car: 1982 Z28
If you're pushing a 412ci engine w/ the stock fuel pump, it won't keep up.
Think about the Walbro 255 high-pressure gerotor pump.
Old Aug 3, 2004 | 12:53 PM
Got a part # for that?
I found a Granatelli Motorsports one, Part #GRN-GM722-2 Fuel Pump, F-Body, In-Tank, Electric, 255 lph, 90 psi, Chevy/Pontiac Camaro/Firebird, are they any good?
So whats a good running and WOT psi? 45psi - 50psi?
Old Aug 3, 2004 | 03:41 PM
kevinc's Avatar
Car: 1982 Z28
If you're running a standard TPI fuel tank setup, part# FPG003 from here:
http://www.autoperformanceengineering.com/
Should do the trick.
As for your question about the right fuel pressure...it varies. Build your fuel system to deliver the same pressure at all points in your RPM operating range.
I like 58psi but I'm running a different engine than yours.
-kevin
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
