timing cover and chain questions
Old Aug 3, 2004 | 09:12 AM
bad_ta_05's Avatar
Car: 85 trans am
Engine: 79 4 bolt 350
im getting a new timing cover and i think im gunna go the fancy way and get the chrome one from autozone i think made by spectra or something. well i looked at it and it doesnt have the timing marker on it. its just sitting in the package. i was wondering how i put that on there when i get it? i dont have to weld it or anything do i? also will a comp cams magnum double roller timing chain fit under it and will it fit the stock size dowel pin in the cam? thanks alot
Old Aug 3, 2004 | 09:36 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
just a heads up...
cheap chrome tin like spectre leak easily... they're a royal PAIN to seal.
if you want it shiny, spend a lil more on a polished cast alum timing cover... same goes for oil pans and valve covers.. just my 2 cents...
anyhoo, the timing pointer bolts on using the same two bolts that hold the cover on. if one didnt come with it, then you need to buy one.. its under $5 and on the same isle as the other spectre stuff.
Old Aug 3, 2004 | 10:20 AM
THEGENERAL's Avatar
Car: 1966 impala , 1998 sebring vert,1978 buick regal turbo, 1991 chevy silverado 3/4ton 4x4 lifted
Engine: 283, 2.5,3.8 turbo 350
Transmission: powerglide,auto overdrive, th350,4L80
ive never had a problem with those covers for the timing chain and yes the pointers just bolt on the cover with two of the bolts that hold on the cover but as MrDude_1 said i have had problems with the cheap chrome oil pans ...they are junk ......just my
Vintageracer
Jan 10, 2020 05:33 PM
drewdock87
South Central
Aug 18, 2015 09:02 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
