ok guys need your help and opinons!!!!!!!!!
Old Apr 23, 2001 | 10:39 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
Transmission: 700-R4
Axle/Gears: 2.73 G80
ok here is the problem. when i drive my car like on the express way the tires start to vibrate when i turn the wheel to the left or right. it will do it to one side then will automatically change on its own. like it will do it to one side then an hour later the other. but the steering wheel doesn't vibrate. also i though the problem was the front tires being worn so i got brand new ones and put them on the front and it didn't fix the problem. i think it was aligned and balaced to. then i looked in my haynes manaul and it says vibrating could be the wheel bearings. Im am like 95% sure it is the wheel bearings. i can't think of what else it could be. nothing in the car vibrates not even the steering wheel. you can just hear the virbrating from the tires. and it gets worse as you go faster around corners. also one more note. it doesn't start till the car has been drive for like 10-15 mintues. Has anyone ever experienced this? also i would love any information you can give me.
thank you in advance
350 vette engine
aluminum heads
235/60R15 BFgoodriches
3"flowmaster exhaust
20% tint
hatch wing
2 12"kicker solos
300 watt sony amp
Old Apr 23, 2001 | 11:08 PM
MikeZ28's Avatar
Car: 92 Z28 Z03
anyone can give me help????????????
Old Apr 23, 2001 | 11:39 PM
bottledpower's Avatar
Car: 85 IROC
Transmission: 700 r4
im betting on the wheel bearings. i could almost guarantee it. pull the wheels, calipers and rotors. it might take an hour to fix.
85 IROC 350 11:1keith blacks,.555lift erson roller cam,1.5 crane roller rockers,edelbrock intake,holley 4150 750dbl pumper, nitrous oxide,full length heddman headers,true dual exhaust, 11"stall converter, 700R4, 3.73 locker
Old Apr 24, 2001 | 10:31 AM
MikeZ28's Avatar
Car: 92 Z28 Z03
anyone else have any ideas?
Old Apr 24, 2001 | 10:40 AM
CamaroZ_85's Avatar
im not so sure it would be the bearings; you would hear noise immediately (not after 10-15 minutes) and it wouldnt go away (switch from one side to the other) take the tire off and grab the rotor and give it a good wiggle, it shouldn't have any play. but if it does, then its the bearings. go ahead and change them if you want tho, it wont hurt anything and at least you can definately rule that out...
85 Z28- 350, Comp 262, Edelbrock Performer intake, Edelbrock 600 cfm carb and Edelbrock cat back, Summit headers and vette servo
-JVC, Eclipse, Pioneer, MTX, Phoenix Gold, Planet Audio
Old Apr 24, 2001 | 11:14 AM
MikeZ28's Avatar
Car: 92 Z28 Z03
it might not take 10-15 min. but to go at least 55 it takes me 10 min to get to the road. cause by my house it is all 30mph i know it only happens when i go like 55. and sometimes if i tilt the steering wheel it wouln't happen but if i move it like a 1/4 of an inch it vibrates.
thanx 4 the help.
anymore suggestions or other ideas of what it can be?
Cleotiz
Jan 6, 2018 08:56 PM
aaron7
Aug 17, 2016 06:02 PM
PestilenceIV
Aug 20, 2015 03:32 PM
Street Lethal
Aug 14, 2015 08:25 PM
Zachattack0925
Aug 12, 2015 09:52 PM
