Can a bad coolant sensor cause a car to run poorly? Code 15 problem! Need answer fast
Old Apr 24, 2001 | 11:37 AM
BrianB's Avatar
I got a code 15 on my 86 Trans Am now, which on here indicates a low tempature reading at the engine coolant tempature sensor. Which I knew was bad to begin with, because it wasn't kicking my fan on. So I just said the heck with it and ran the fan manually and didn't worry about the sensor. But the car runs terrible at first startup. If I let it run for a bit and drive it, the SES light will eventually turn off.
Old Apr 24, 2001 | 01:02 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes! The computer uses the temp of the coolant in many of its calculations to know how much fuel and timing to add. If its reading wrong it will cause the computer to make the car run poorly.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
fonzie85
Aug 13, 2015 11:50 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
mustangman65_79
Aug 8, 2015 12:07 PM
