fuel line
Old Apr 22, 2001 | 10:43 PM
v6-3.1's Avatar
fuel line
how can I tell that I have a fuel leak, the self diagnostic shows no codes except for 35(IAC), that cant be the cause for 8 miles per gallon. Its gotta be something else. I did a tune up (every thing except for the distributor cap). could the ignition timing be the problem, please tell me the possible causes so that I can check them?
Old Apr 23, 2001 | 06:34 PM
ede's Avatar
ede
fast and easy way is to open a fuel line fitting a little and see if fuel sprays out, it should. do this after it's sat a while and had a chance to bleed off. check the charcol canister, regulator, injector, t-stat, engine temp senser
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 24, 2001 | 01:36 PM
Steve89GTA's Avatar
Exactly what do you 'check' when you check the fuel canister. Mine has a little dent in it.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
