What should Fuel pressure be
Old Aug 3, 2004 | 06:56 PM
IroczInOz's Avatar
Anyone know what the fuel pressure should be when the car is running.
I know that the fuel pressure is tested with the vacuum line disconnected but I just installed a digital gauge, and was wondering what the pressure should be with the vacuum line connected and under normal circumstances.
I just did a quick check with the vacuum line disconnected it was at 42.5PSI.
With the Vacuum line connected it went down to about 37.5PSI
What should I be aiming for as far as fuel pressure goes?
305 TPI Chev IROCZ.
Old Aug 7, 2004 | 01:24 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Both of those numbers are right in the ballpark. With the vacuum line connected the pressure should drop a little(from the disconnected pressure) while the engine is idling. When you floor it the pressure should go up near the pressure you had when the line was disconnected.
Old Aug 8, 2004 | 05:49 AM
IroczInOz's Avatar
Sweet thanks for the good info.
92camaroJoe
Jul 29, 2023 07:57 PM
R3500
Aug 17, 2015 12:16 PM
wayshegoes
Aug 17, 2015 12:00 PM
92camaroJoe
Aug 13, 2015 06:07 AM
Kaweh
Aug 9, 2015 02:54 PM
