My car has led me to drinking!!!!!!
Old Apr 23, 2001 | 08:34 PM
RED91Z's Avatar
can anyone help me with this problem??? I have a 91 Z28 with the 305 TPI. The problem is that I can start the car when it sits for awhile then it idles for about four minutes then it justs dies. I can rev it up to good RPMs while it running then it just goes flat line and won't restart. At first it thought it was the control module but so I put another new one in it did the same thing. It has new coil, wires, cap, rotor, and control module, and new fuel pump, and fuel filter. What would be the problem I start the new season racing on Sat need to fix now before the makes me a drunk. Thank you
Old Apr 23, 2001 | 09:07 PM
rezinn's Avatar
First of all you want to start with the basics: do you have a vacuum leak? Is your emissions equipment working properly(all those stupid little sensors!)?
What happens when it dies? The rpms just fall and a check engine light comes on? Is it flashing any check engine lights? Do you smell fuel?
The more info you give us the better we can help. Whats your mothers maiden name? Place of birth?
Old Apr 23, 2001 | 09:16 PM
RED91Z's Avatar
When it dies it dies no light no fuel smell nothing just flat line and when you go to restart it it just keeps turning over with no fire.
Old Apr 23, 2001 | 09:39 PM
Mo's Avatar
Mo
bad injector maybe...
try disconnecting them one at a time
90 IROC 5.7l (L98)
ram air, K&N's, air foil,Flows
LIKE A ROC
Old Apr 23, 2001 | 09:43 PM
Vader's Avatar
Red,
Check the pickup coil for cracks and continuity when heated. You can also check the reluctor for cracks. The two must work together to produce an adequate signal for the EST/HEI module to amplify and operate the ignition coil.
A cracked pickup coil can work when cold, but will expand slightly when heated, opening the circuit and causing no spark. Wait for the engine to cool thoroughly, and it might start right up again, only to die again after the distributor gets warm. You should be able to read between 500 and 1,500 ohms on a good pickup coil.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old Apr 23, 2001 | 10:41 PM
Kwiksilverz28's Avatar
Sounds to me like it woun't idle after it switches into closed loop, which would lead me to think computer problem. I think that if you would disconnect your oxygen sensor, it would cause the computer to stay in Open Loop, abling you to fix the problem..
98Z28 M6 Flowmaster HPP3 K&N
91RS TBI A4 Flowmaster
"recalculated" emissions
Old Apr 24, 2001 | 05:45 PM
vortech305's Avatar
had the same problem had to change battery and alternator.
92' camaro
New 305 block TPI conversion, Flat top pistons,Bore over .30 Forged parts all around,Edelbrock intake,ported plennum,ported corvette alluminum heads, accel cam,52mm throttle bodie, SLP runners Home aid cold air induction, Air foil,ford SVO 19lb injectors,fuel regulator,cloys timing chain, comp alluminum roller rocker arms and pushrods MSD 8.5 mm wires, bosch plattinum plugs, hypertech cap & rotor and coil, Edelbrock TES headers, free flowing catalytic converter and a 3 inch force II flowmaster exhaust system, and a 3 inch cutout,Zoom multi friction clutch, T-5 tranny,billenstien shocks&struts.
Soon to come!!!
Procharger system 12lbs o boost.
New paint job(hawaiin orchid purple)Cast alluminum ZR1 rims w/ 275 tires.
Favorite quote: "where ever u go, there u are"
Other car;
1971 plymouth Duster
Mods:340,edelbrock victor jr. intake, 650 4 barrel holley, heddman headers,40 series dual flowmasters, cold air intake,4:10 gears, just got a new paint job and cragar rims with 315 tires in the back.
:Yeah its not a chevy but damn how many 71' dusters have u seen in the streets.
Old Apr 24, 2001 | 06:56 PM
MTCAMARO's Avatar
Car: Camaro sc
Engine: 350 cid.
Dad bought a formula firebird to resell and it was doing the very same thing.It was the 305 tpi also.Turns out it was the oxygen sensor.
Old Apr 24, 2001 | 06:59 PM
Z's r Best's Avatar
Car: '86 IROC, black and sharp
Engine: 305 tpi, bone stock
Axle/Gears: 3.42 pos w/rear db
When I bought my 86 IROC the previous owner said it would die after starting (305 TPI). He said he had been told the injectors needed "professional" cleaning. IT would restart, but die again. I did run a bottle of injector cleaner through it (even though he said he did it regularly). But the thing that helped most was to turn the key on, wait till the fuel pump kicked off and then start it. It has only died once in the 2.5 months I've owned it. When an engine dies it ran out of gas or spark (unless the air filter is plugged tight with dirt and it runs out of air).
Z's r Best
Old Apr 24, 2001 | 09:31 PM
RED91Z's Avatar
Well worked on the car most of the day. i had a mechanic tell me that if you let them sit a lot the fuel pump goes bad so I went out and bought a fuel pressure gauge set up for I could tell what pressure I had at the schrader valve and when I hooked it up I got very little pressure but then it climbed up to 40 psi slowly after turning on the key a couple of times. So I checked the fuel filter clean as a whistle. Then I turned on the key fuel pumped out of the line great. So I took the fuel lines apart at the manifold turned on the key again great pressure there to. But my gauge says 0 or very little pressure then it will slowly climb on up. Is it the fuel pressure regulator or what is it? It has me stumped.
Reddeath210
Oct 6, 2015 08:20 AM
OLDYELLR
Car Audio
Sep 30, 2015 07:10 PM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
fonzie85
Aug 13, 2015 11:50 AM
