Coolant sender location
Old Apr 25, 2001 | 12:08 PM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
The gauge stopped working the other day right after i changed my spark plugs (that was fun) I remembered that there was a sender between the last 2 spark plugs on the pasenger side. While i was checking it out, the connector broke. No problem, got a new connector and a new "coolant sender" I think that the sender with the broken plug was for the fan. Where is the gauge sender?! I found a sender below the TB, but its not the same as the sender i bought. It has a 2 pin connector on it. I disconnected it, and i got a C?S code 13? I need my gauge back!!
  • 89 Formula 305 WS6
    SFC's
    LCA's
    Spohn Panhard Bar
    Air Foil
    Flowmaster Cat Back
    Tranny Cooler
    A/F Ratio Meter (not a mod but it sure spurs interest)
    Trans Temp Gauge
    Most "Free" Mods
    3:73, Zexel Torsion Posi
  • 90 Eagle Talon 2.0
    (Winter Beater)
    Mods? Um, no
Old Apr 25, 2001 | 01:05 PM
Vader's Avatar
Omega,
The CTS for the gauge should be at the left (driver's) cylinder head. The one at the front of the intake coolant crossover is for the ECM temperature reference.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old Apr 25, 2001 | 02:25 PM
Omega's Avatar
Engine: LS1 / LS3
Thanks Vader! How many temp senders does this thing need!!
Old Apr 25, 2001 | 07:59 PM
Andy89RS's Avatar
3. Guage sender is in drivers side head between cylinders 1 and 3, ECM sender is in manifold, and cooling fan switch is in passenger side head between the 6 and 8 cylinders.
Bubbajones_ya
Jul 6, 2024 08:32 PM
m00n420
Sep 11, 2015 02:39 PM
FormulasOnly
Sep 10, 2015 09:07 PM
Ironhead38
Sep 7, 2015 02:26 PM
tonys91rs
Sep 2, 2015 07:07 PM
