will 9 bolt axleshafts go in a 10 bolt?!?!?!
Subscribe
Apr 25, 2001 | 01:14 PM
hey, im lookin to upgrade my 10 bolt posi unit to the slp take off unit but it uses 28 spline axles and im pretty sure since i have an 87 gta that i have only 26 spline axles. Is it possible to put the axleshafts from a 9 bolt disc rear into a 10 bolt drum rear and make it work, since the 9 bolt has 28 splines?!?!?! i know its a 7 3/4 rear as opposed to the 7 1/2 10 bolt i have in the car now, but i dont wanna go out and spend more $$$ if i dont have to! if it doesnt work, please let me know and if i have to get new axleshafts with 28 splines where should i buy them from that is cheap but strong??? i went to the junkyards but found crap. what are some good companies tha sell em cheap????
Reply 0
Apr 25, 2001 | 02:19 PM
No, they are not interchangeable.
Reply 0
Apr 25, 2001 | 04:05 PM
9-bolts have 26 spline axles, and nope, they're not interchangeable with 10-bolts, like madmax said.
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.23 @ 107.62 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Reply 0
Apr 25, 2001 | 08:45 PM
10 bolt axles are held in with a c-clip. 9 bolt axles are held in with an external mounting flange like a ford 9".
The only thing compatable between those diffs are the external mounts. Inside they are completly different differentials with nothing interchangable.
You can get very good aftermarket 10 bolt 28 spline axles from www.tomsdifferentials.com or www.drivetraindirect.com for $125 each. Part number KAC7-A7. They'll work in all 10 bolt third gen diffs from 82-92 as long as you have a 28 spline carrier.
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Reply 0
Subscribe
