92 LT1 Code 45 help.
Old Aug 7, 2004 | 05:21 PM
GMJim's Avatar
Hello all.
Great site!
I recently had a code 45 set on the car (92 LT1) Rich o2 left side. and my AutoXray 6000 says I am running a little rich on the left bank. I did an injector leak down test on the car today and after 20 min. there was no leak down at all. Then I did a drop test on all of the injectors and they all dropped the same except #5. I couldn't get #5 to fire with the injector tester. I checked the resistance on all of them and got 13.2 Ohms on all but #5. I got 4.1 Ohms on #5. Obviously I have a problem with #5 injector but what I can't figure out yet is why I'm getting a rich code #45 on the left bank when my testing shows I have a problem with one injector NOT firing. Could the lack of resistance in the #5 be causing some sort of electrical glitch with the rest on that bank??? The 92 Vette is a Batch fire system, not sequential.
I'll likely change the #5 but anybody got any ideas???
Thanks for the help.
Jim
Old Aug 9, 2004 | 06:35 PM
GMJim's Avatar
Ok. Since nobody wants to take a shot at the rich lean thing, could anybody recommend a set of quality replacement injectors? A replacement Multec from the dealer is $155.00 my cost, so I think if I can get a real good matched set it may be the way to go..
Jim
Old Aug 10, 2004 | 11:34 AM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Try sending out your injectors to www.cruzinperformance.com. They test and flow match all your injectors for less than the price of one new one.
Old Aug 10, 2004 | 12:55 PM
GMJim's Avatar
Thanks for the reply.
I can buy 8 new matched Accel 24 lb. injectors for $229.95 at Summit. I've been on the phone all morning trying to sort this out and have spoken to several people. Most of them don't seem to have a clue what they're talking about. Any of the jobbers I call only sell Borg Warner or Delco and they are expensive!!! I thought there may be some people on this site that have tried some of the aftermarket injectors. The rebuilders and carb shops want about $35.00 each ($280.00 plus tax) to clean and check mine but if I can buy a new set for $230.00?? You know what Homer would say (Doh!)
Jim
BumpaD82
Feb 26, 2016 02:57 PM
L0tuS
Oct 4, 2015 08:07 AM
New2Chevy
Sep 28, 2015 12:35 AM
3rdgenkindagal
Sep 13, 2015 02:02 PM
L0tuS
Sep 4, 2015 11:16 PM
