Smoke at stoplights
Old Apr 25, 2001 | 12:30 AM
91RSconv's Avatar
Smoke at stoplights
Can anyone tell me the source of the smoke that is coming out of my engine when I sit for a while at say a stoplight? It is not thick smoke but it is not normal for a car with 72,000 miles. I just installed an open air element and now this is happening. Did I do something wrong? Anyideas would be great.
91' red RS convert.
71,000 miles
89' IROC hood
red Z-28 16" rims
potenza re730's
MSD ignition
MSD coil
K&N fiter
350 ported polished heads
hypertech chip
flowmaster 40 series cat-back
Old Apr 25, 2001 | 02:21 AM
Hummer's Avatar
Car: 1986 Z28
Transmission: 700-R4
What color is it? White can mean you're burning some coolant, black usually means oil. After re-reading this, do you mean out of your exhaust or the engine itself? A little more info, please.
Old Apr 25, 2001 | 03:20 AM
72Formula400's Avatar
what did you do with your PCV hose that was connected to the old air cleaner? It could just be smoke coming out of there.
Old Apr 25, 2001 | 05:51 PM
91RSconv's Avatar
white smoke.
91' red RS convert.
71,000 miles
89' IROC hood
red Z-28 16" rims
potenza re730's
MSD ignition
MSD coil
K&N fiter
hypertech chip
Old Apr 26, 2001 | 10:40 AM
Polecat's Avatar
Out of the engine area or out of the exhaust?
If out of the tailpipes......not good.
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,TRW Forged pistons,10.7:1 compression,HPC Coated RPM intake, Speed Demon 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, Comp Cam 1.6 roller rockers, Comp Xtreme 284 cam,240/246@.050 with .540 lift,Crane pushrods,ATI damper,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with Hughes 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
FormulasOnly
Jul 23, 2018 08:47 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
KCG
Sep 23, 2015 09:05 AM
Accerrito22
Sep 5, 2015 09:34 PM
