fuel pump fuse
Old Apr 25, 2001 | 05:29 PM
SiDeWaYS Z28's Avatar
fuel pump fuse
i'm trying to change the fuel filter but dont know which fuse controls the fuel pump so i can relieve the fuel preasure. all the diagrams i have are different than the block in my car. i have a 91 z28 with a 5.7L. There are two inj 01 and inj02, is it one of those? please help?
Old Apr 25, 2001 | 06:42 PM
SUPER-SPORT-CHEVY's Avatar
Man do i feel sorry for you a fuel pump in that car is a PITA. You dont need to take a fuse out to change it there isnt ,mutch pressure in the system when it is off so you will be fine. GL!
SSC
Old Apr 25, 2001 | 06:43 PM
Never mind the pump post "my bad" i read your post to quickly. but if the key is off only a little fuel will squirt out.
[This message has been edited by SUPER-SPORT-CHEVY (edited April 25, 2001).]
Old Apr 25, 2001 | 08:22 PM
406TPI's Avatar
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
The fuse is typically back by the tank. There should be a little fuse housing bolted up the the sheet metal between the tank and the back seats. You really don't need to bother though. If the car has been off for awhile, the pressure will bleed down by itself. You might want to have a drain pan handy when you disconnect the lines for fuel will spill out. Cold gas running down your arm sucks
[This message has been edited by 406TPI (edited April 25, 2001).]
Old Apr 26, 2001 | 11:30 AM
90RS's Avatar
The fuel pump fuse is actually up by the battery in my (90) camaro in a black housing. But i just replaced my fuel pump and did not need to take the fuse out there is not much presure. gl
john
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
