Quick helicoil for sparkplug question.
Old Aug 9, 2004 | 03:00 PM
LaxStreetRacer's Avatar
Car: 91 Z28
It looks like I might have to put a helicoil in a friends car and I would really rather do it with the head on, but thanks to gravity any metal shavings are going right on top of the piston. What would be the best way to make sure i get that crap out. Im thinkin if i have that cylinder up near TDC somewhere i can maybe use compressed air to just blow it out. Anyone have any experience with this? Im sure a magnet would do just fine but im afraid he might have an aluminum head.
Old Aug 9, 2004 | 03:18 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
vacuum cleaner
Old Aug 9, 2004 | 03:20 PM
Car: 91 Z28
Yea, i know but mine sucks! .....errr, actually it doesnt.
Old Aug 9, 2004 | 03:32 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Get another one that doesn't suck.... or, that sucks worse (better). Whatever.
Ummm, more.
Old Aug 10, 2004 | 02:25 AM
84 Restore's Avatar
Car: 1984 Z28 camaro HO Gun metal Gray
Engine: 305,L69 H.O. rebuilt
Uguys are KIlling me
Old Aug 10, 2004 | 08:30 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
i have been told that putting grease on the tap is suppost to catch some of the metal fragments.
honestly, ive never had much luck with the method.
i would try a good shop vac... i wouldnt blow it with compressed air as you might jam some particals between the piston and wall...
Old Aug 10, 2004 | 08:34 AM
Car: 91 Z28
Thanx for the input guys. I have had a litte woops with a helicoil in the past as well, so im a litte aprehensive about the whole thing. Then i talked to the guy(who doesnt know jack about cars) lastnight and from what he was saying it sounds like someone else already may have done a heli-coil in it once all ready. If thats the case im not even gonna touch it.
Old Aug 10, 2004 | 09:10 AM
DonP's Avatar
Car: 1990 GTA Black/Black lthr
Engine: 305 TPI stock
I read an acticle about porting the TPI and these nuts didn't give a rats @$$ about allowing aluminum shavings getting into the combustion chamber. They just stuffed rags in the ports. They said the soft metal would melt and blow out the exhaust.
Personally, there is NO WAY I'd allow metal into the combustion chamber, but if you feel risky, I thought I'd throw this out.
The guy said everything turned out fine in the end, FWIW.
F-body-fan
Jan 12, 2023 01:49 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
meeklay812
Oct 1, 2015 03:46 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
3.8TransAM
Sep 27, 2015 08:37 PM
