ANYONE HAVE A POSSIBLE DIAGNOSIS FOR THESE SYMPTOMS?
Old Apr 24, 2001 | 11:43 PM
speedlvr's Avatar
The tach jumps around irratically while driving. I've moved all wires away from the coil and tach wires and it still does it. Also, there is oil around the #1 & 3 spark plugs. Runs strong with a slight surging (once in a while) when in closed loop. In open loop, hesitation with moderate acceleration or going up a hill.
Old Apr 25, 2001 | 07:54 PM
speedlvr's Avatar
nope.
Old Apr 25, 2001 | 10:39 PM
ViciousZ's Avatar
Car: 91 camaro
Engine: 383
What is it? TPI, TBI, carb? And does the actual idle of the car jump around with the tach?
Old Apr 26, 2001 | 08:04 AM
speedlvr's Avatar
It's TBI. Only the needle flops around, the actual rpm's are steady. Thanks.
Old Apr 26, 2001 | 06:47 PM
dtbracing's Avatar
I had the tach problem a few years ago, replaced tach filter, tried new tach, nothing helped. Eventually found that when tach wire and coil wire were seperated, it quit. I slipped a vac. hose over the tach wires entire length to insulate it. Overboard....but it worked.
Old Apr 26, 2001 | 10:01 PM
speedlvr's Avatar
I've learned that sometimes you HAVE to go "overboard" to take care of a problem, for lack of a less drastic means. I replaced the distributor and now all is well. The old one was under warranty so I didn't have to put out any money. Thanks.
db057
Jan 10, 2020 08:55 PM
Elephantismo
Feb 13, 2019 12:51 AM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
Magman
Sep 12, 2015 11:55 PM
