Need some help on vibrations PLEASE!!!!
Old Apr 27, 2001 | 01:23 PM
Pat Westerkamp's Avatar
My Z28 started just recently getting a vibration it first started going about 60mph and accelerating hard but not kicking the tranny down the car would shudder< let off the gas and it would stop hit again and it would come back I thought u-joints.
I had new high performance joints put in and had the drive line balanced while I was at it.
The vibration is almost none existant but now it gets a vibration that starts at about 80 and gets worse as you go up and gets louder when you let off the gas. Some help would be greatly appreciated I dont want to throw money were it is needed
THANKS
Old Apr 27, 2001 | 01:33 PM
92 RSS's Avatar
Car: 1992 Camaro RS
Engine: 5.7
I got the same problem, it starts at about 65. I see you changed the u joints and it helped out a bit. I was thinking of doing the same. But mine feels like an air problem. Which I'm in the process of possibly fixing. I think my glass hood is poping up a little and allowing it to catch some air. I'm installing 2 more hood pins to see if that helps. Hopfully it will, it's been a while since I got it over 80 without it feeling like it's going to implode.
92 RS, 350, Street & Performance MPFI, TFS heads,
Crane Rollers,
MSD Digital 6 Plus, 22lb injectors,
ZZ3 cam, Edelbrock Headers 1 5/8, 3" Exhaust,
Hi Flow 3" Cat, stock T-5,
stock rear 3.08, koni yellow adjustable front, twin turbo glass hood, T-tops, Auto Meter Ultra Lite Series 2 5/8 gauges, Teal Green
Old Apr 27, 2001 | 03:12 PM
I now what you mean Ill have to watch the hood although it sound like its underneath.
thanks
69GTOby
Apr 18, 2016 02:34 PM
sac92transam
Oct 7, 2015 02:31 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
