120mph
Car: 1982 z28
Transmission: th350
120mph
i was so impressed by the fact of runnig @ 180 degrees that i went for broke on the interstate and tried to get the b****** to overheat at 120mph it seemed to have lost its umph seems like a compression thing,kinda weird i slowed and everything seems to be normal good news ,it only rose to 185 190 in the process,that air dam was the cure thanx fellas, still got a few bugs after the swap but man im tellin you, this **** aint playing,why would it do such a thing
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
With the exception of the 88 I think all the following years had the speed limiter set to various limits. The 88 years tehmselves are naturally governed
. Thread Starter
Car: 1982 z28
Transmission: th350
no computer crap at all straight 350 w/ a performer intake edel 500 carb mallory dist and coil small cam all good except for this and belive me there were some bugs
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Speed limiter? I'm the original owner of my 88 LB9 IROC. When I got it, and soon after break-in and first oil change, I took it out on the back roads to see what it would do. It was still accelerating through 135 when I chickened out. Mind you, the car was stone stock when I did that. No tweaks or mods at all.
Doesn't look like my car has a speed limiter.
Car: 87' IROC
Your IROC came with the 245/50 high speed rated tires. These cars didn't get a limiter. The cars with "regular" tires like RS's got the limiter.
