120MPH Speedometer
Old Dec 8, 2000 | 12:15 PM
El Guapo's Avatar
120MPH Speedometer
In my old 89 firebird l had a 120mph speedo. My 87 T/A has an 85MPH speedo. Will a 120MPH cluster bolt in place of an 85MPH cluster, and provide the correct speed information?
FWIW, the 87 does have the electric VSS and not a cable.
Old Dec 8, 2000 | 09:46 PM
El Guapo's Avatar
So, l will be the first to try. ls that correct?
Old Dec 8, 2000 | 09:58 PM
Vader's Avatar
Guapo,
The electric (pulse-reader) speedo heads only count and register the number of pulses from the VSS. A 120 MPH head can just display more of them. As long as the speedo from the '89 is a pulse reader, it should work fine. Of course, the connections and mountings need to be the same. If the connectors are different, you may have a chore ahead of you.
Later,
Vader
"No matter how hard you try you can't stop us now"
Adobe Acrobat Reader 4.0
Old Dec 9, 2000 | 06:42 AM
El Guapo's Avatar
Thanks.
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
