clearancing the block and went a bit too far!!! help?
Old Aug 13, 2004 | 09:06 PM
AC's Avatar
AC
Car: Used to drive a camaro
Well, I'm already 500 bux into machine work on my 383 4 bolt block. I have bought my entire eagle forged balanced 383 bottom end and got the block back from boring/honing/cleaning. I was "notching" the block for my first time and did not realize the water jacket/passage extended that far down and have now grinded a bb size hole into my water passage throught the very edge fo the cylinder wall right above the oil gasket area. Is this salvagable if I can have the machine shop weld the hold and grind it away? Or is my block scrapped now? I would really appreciate your peoples experiences/advice.
Old Aug 13, 2004 | 09:13 PM
92Z's Avatar
92Z
Use "Hard Block". A short fill will go to the bottom of the water pump holes.
Old Aug 13, 2004 | 09:18 PM
AC's Avatar
AC
92z, is this Hard Block just a temp fill so when a weld puddle is formed you empty it? Do you think this mistake is going to scrap the block?
Old Aug 13, 2004 | 11:07 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Hard Block is concrete that goes inside the water passages inside the block. It will seal the hole and strengthen the block.
I'd have it welded myself, actually i might hard block it... I don't know ask the machine shop what to do.
Old Aug 14, 2004 | 08:08 AM
StangKiller's Avatar
Get it welded by a shop that does this kind of work, I think they have to use a Nickel type welding rod, no way would I trust hard block to seal a hole.
Old Aug 14, 2004 | 08:18 AM
ede's Avatar
ede
do a 1/2 filler with block grout. should of done that before you started but do it now and it should be fine.
Old Aug 14, 2004 | 01:16 PM
92Z's Avatar
92Z
Lots of machine shops require you to fill the block before they clearance it. That way they don't have to worry about hitting a water jacket. If they clearance without filling there is a possibility that the block will pass a pressure test, yet may have a paper thin spot that breaks open when the engine is running.
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
Nick McCardle
Sep 10, 2015 08:36 PM
