Distributor Diagram
Old Apr 28, 2001 | 02:33 AM
auxout's Avatar
Car: 92 RS
Engine: VSux
Transmission: Flux Capacitor
Distributor Diagram
Does anyone have a decent (blow-out? the kind where it's all taken apart) diagram of a distributor, I have a 92 RS 3.1L and I keep getting a code 45&43, rich and low voltage to EST. I am planning to take out the distributor and clean it before i try to replace it. This is the last thing I can think of to fix the problem. Anyone else ever get a code 45?
1992 RS 3.1
1985 POS (SC 2.8 CFI)
Old Apr 28, 2001 | 08:06 AM
El Guapo's Avatar
The distributor is really easy. There is a roll pin through the bottom gear. Remove. WATCH HOW IT GOES BACK!! Then the Rotor button and below will just pull up through the tube. It may take a bit of elbow grease, but there arent any secret screws here. To get the pickup coil, under the rotor button, there is a snap ring, may be hidden by grime.
The rest should have easy to see bolts holding it in.
Clayton
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
SavingPvtEric
Sep 29, 2015 05:59 PM
Damon
Sep 26, 2015 04:29 PM
