What is the right way to remove a rod bolt?
Old Aug 13, 2004 | 10:08 PM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
I have a set of rods that I'd like to install a set of ARP bolts into. After the bolts are in, the rods will need to be resized on the big end, which I plan on having done professionally.
But in the interest of saving a few $$, I'd like to R&R the bolts myself if possible.
Is that a job that can be done at home?
If so what would be the correct way to do it?
Thank you
Old Aug 14, 2004 | 11:54 AM
82355's Avatar
Using a press.
If you have one at home and a way of supporting the rod when you press the new bolts in then you are fine. If not, just let the machine shop do it. I believe that is generally included in the cost of reconditioning rods anyways.
Martin
Old Aug 14, 2004 | 12:53 PM
ede's Avatar
ede
press is the way to go. i did make a jig from a piece of 4" channel and some 3/8 sq. to hold one end of the rod and use air hammer. i doubt you really save much doing it yourself, but i guess it all adds up.
Old Aug 14, 2004 | 03:53 PM
Car: '85 IROC
Engine: LB9
Yeah, after I thought about it I changed my mind, cause they have to square off the surface where the cap goes before the new bolts go in anyhow.
Thx
theurge
Aug 21, 2015 12:46 PM
LT1Formula
Aug 20, 2015 09:36 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
3rdgenparts
Aug 8, 2015 07:09 PM
