Octane, Oil weight, spark plugs, what temp should I be expecting?
Old Aug 13, 2004 | 11:16 PM
Cameron's Avatar
Car: 1985 Z28
Transmission: 700-R4
Dang it guys, the more I think about this camaro the more I think I am going to screw it up. The person I bought it from has NO idea what weight oil, temp, spark plugs or octane to use....here is my engine info.
350 Chevy, 9:1 Compression (Forged pistons), Steel Crankshaft, AFR Aluminum Heads and Rocker Arms, 2.02 Valves, Super Ram Intake Manifold, 36 lb. Injectors, 500 HP Fuel Pump, 6 lb. Paxton Supercharger, Custom Headers, 3 inch Flowmaster Exhaust, Accel MSD Electronics, Worked 700 R4 Transmission
I haven't even got to see it in person yet and I am stressin out. Should I be running 94 octane or lower? What temps should this engine be safe at? What should I expect the transmission temps to be? How often should I change my supercharger oil? How much is a rebuild kit? How much does one dyno run cost? UGH
I have already ask some of these questions but i am in a bit of a last second buyers remorse panic...
I want to install B&M shifter, Trans cooler temp gauge and cooler.....
Cameron
Old Aug 13, 2004 | 11:29 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Alot of those answers can be found using and clicking here
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
db057
Aug 22, 2015 08:17 PM
