Help...Spark in engine bay
Old Aug 13, 2004 | 11:31 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
I was putting a spark plug in today while I was doing my header install. Stupid me didnt disconnect the battery this time. While tightining the spark plug there was a spark. After that nothing powered up when I turned the keys. My alarm light was blinking rapidly and my horn kept beeping at a slow pace lightly. How bad did I mess up? What do you think happend? I have the battery unpluged now but I havent pluged it back in since im in the middle of a header install. Any help is appreciated.
Old Aug 14, 2004 | 12:02 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Where was the spark?
Old Aug 14, 2004 | 12:27 AM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
The spark was from the spark plug to the wrench, possibly touching the head.
Old Aug 14, 2004 | 01:14 AM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
I don't know how the hell that can happen. There should be no electrical charge or even static electricity there. Did you happen to hit an wires, starter, or battery?
Old Aug 14, 2004 | 01:17 AM
profiveo's Avatar
Car: 1992 Camaro Z28
Engine: 350 L98
I dont think I hit anything at all. I know for sure I did not hit the battery. I was working on the last plug on the passenger side. I will look again tommorow to see if I may have hit something.
Old Aug 14, 2004 | 01:02 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
I was working on the #8 plug and I think I probably hit one of the starter wires.
Old Aug 14, 2004 | 01:08 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
take a good look at the rear in that area, you may have pinched the wire to the starter in the header flange if this is the case fix it before you hook up the batter and burn some major wiring. that is the only thing i think you could of done at that location.
Jeff
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You could have melted the fusable link between the starter and the battery.
Old Aug 14, 2004 | 01:20 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
What does a fusible link look like and how can I tell if its shot?
Old Aug 14, 2004 | 01:31 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Well I touched the negative cable to the battery and my alarm started going off with my horn. My bro said the instrument cluster lights were also blinking but the courtesy lights did not come on when he opened the door.
Old Aug 14, 2004 | 01:46 PM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Another update: we plugged the negative all the way back into the battery and everything appears to be fine The lights where you put your feet light up, instrument cluster powers up, radio works so I think I didnt mess anything up hopefully. I just hope she starts up. I cant wait to hear it! Thanks for the help guys.
Orr89RocZ
Apr 25, 2016 08:28 AM
Reddeath210
Oct 6, 2015 08:20 AM
Polo Z03
Sep 10, 2015 06:43 PM
AkDrifted
Aug 17, 2015 07:45 PM
jahblah
Aug 12, 2015 05:54 PM
