Can I get rollar lifters for my non rollar block?
Old Apr 28, 2001 | 05:17 PM
Jer82Z28's Avatar
Car: 1987 IROC
Engine: Vortec 350 TPI
Transmission: 7004r
I'm not too certain if i have a rollar block, are there any rollar lifters that can be used?
will they work with a hydraulic cam as well?
I've had several people say you gain tons of performance with rollar lifters, like 30hp
anyone experianced this?
Old Apr 28, 2001 | 05:57 PM
Biochem's Avatar
Car: 2002 SOM z28
Dude... before you get too far ahead of yourself, you may want to read a few things about cam shafts in general. Roller lifters vs flat tappet... solid vs hydrolic... what year car do you have?... stock springs?... torque converter?... gears?... heads?... There are SOOOO many things you need to take into consideration before you go about choosing the proper cam for your car.
FYI- hydrolic roller lifters started around 86 or 87 I think. I have flat tappet hydrolics in my 84...
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Apr 28, 2001 | 07:28 PM
ede's Avatar
ede
to answer your question yes you can run roller lifters in a non roller block, you just have to go with aftermarket parts, at a very high cost. like you were told you should check out comp ot lunati catalogs for some basic info.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 28, 2001 | 08:13 PM
R.O.B.'s Avatar
'87 started the factory roller cams in both the 305's and 350's.
Rob
'86 TA 305 TPI
Gutted MAF, Ported Plenum
TB Bypass, Home made Cold Air Intake,
Edelbrock T.E.S.
FormulasOnly
Jul 23, 2018 08:47 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
skinny z
Oct 5, 2015 06:23 PM
RyanJB
Sep 14, 2015 03:39 PM
dimented24x7
Sep 6, 2015 03:51 PM
