Leaking Injectors??? Please Help
Old Apr 28, 2001 | 04:39 PM
Jas89TTA's Avatar
Is this a sign of leaking injectors. At shut off the fuel pressure was at 40 psi at 3:16pm, 35 psi at 3:26pm, 28 psi at 3:32pm, 20psi at 3:30pm, 12 psi at 3:50pm, 8 psi at 3:56pm, 5 psi at 4:08 it's lost almost all pressure in One Hour!!
I can also smell a strong fuel odor in the oil and the #1 plug was wet with fuel when I pulled it out cold. The injectors were check by a place here in town and I was told they were fine so I installed them in the newly rebuilt engine. Does this sound like bad injectors? If so I'm planning on pulling the rail off tomorrow and placing a towel uner the rail and let the system prime up and see if they start to leak. I just want to see if ya'll think it's injectors before I go thru the hassle of tearing it apart. Thanks
Old Apr 29, 2001 | 08:23 AM
ede's Avatar
ede
maybe, i believe a bad fuel pump would also do this. since it seems you have a gauge preform the fuel pump preasure check as in your manual and see if it puts out enough.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 29, 2001 | 04:03 PM
John Boy's Avatar
My pressure would go from 40ish to 0 in less than a second. My fuel pump was at fault.
jklein337
Sep 19, 2018 06:23 PM
92projectcamaro
Jan 18, 2016 08:00 AM
BAMiller
Sep 14, 2015 06:38 PM
greenyone
Sep 2, 2015 03:39 PM
