fuel pump won't turn off
Old Aug 18, 2004 | 07:59 PM
1988-305-tbi's Avatar
engine is hard to start cranks for 5-10 seconds when cold, it just started doing that yesterday. fuel pump wont turn off even after the key is removed from ignition fuel preasure is normal, going into the throttle body, and out of the return. the car runs fine after it starts. if anyone has any ideas please help.
Old Aug 18, 2004 | 10:07 PM
now the fuel pump doesn't turn on untill i've cranked the engine for a while. it usually turns on right after i put the mey in the ignition
Old Aug 18, 2004 | 10:46 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
replace the fuel pump relay, it's taking a long time to operate because it is falling back on the fuel pump/oil pressure sending switch to operate the pump after oil pressure builds up to about 4 PSI.
Old Aug 18, 2004 | 10:48 PM
Cadillac's Avatar
Car: '91 Firebird Convertible
Engine: 305 TBI (LO3)
Transmission: 700r4, Vette Servo
Axle/Gears: 3.27 9 Bolt, PBR disks
I had the same problem on the '91. The mechanic did just what Trix mentioned. It was about then that he noticed the hole in the fule tank.
Old Aug 19, 2004 | 08:18 PM
replaced the fuel pump relay, the old one was hissing. but to my suprise same problem no change. any other ideas, it's not the relay, oil pres. switch, fp fuse, what else could it be?
Old Aug 19, 2004 | 08:21 PM
oh yeah it also through a code 54, fuel circuit.
RazorN8
Jan 7, 2022 11:44 AM
9192camaro
16
Feb 3, 2019 12:21 AM
Derick15
Sep 17, 2016 05:28 PM
justin57
Aug 20, 2015 07:05 PM
Kaweh
Aug 9, 2015 02:54 PM
