broke thermostat bolt
Old Aug 18, 2004 | 08:10 PM
rp_guy's Avatar
Car: '86 Z28
Engine: 305 LG4
Transmission: 700-R4
it was on very tight, and i snapped off the top of the bolt, no threads open?
ideas?
Old Aug 18, 2004 | 09:22 PM
JeffW's Avatar
Car: candy blue 85 z28
Engine: 305 tpi LB9
Transmission: 700r4 crazy beefed up one
Axle/Gears: ones with teeth
jet a set of easy outs. drill a hole in the bolt and use the easy out to remove it.
Old Aug 20, 2004 | 07:42 AM
Vader's Avatar
A 3/16" left hand drill bit would be worth a try. Just be certain you spot punch the very center and drill straight down the center. If that doesn't work, step up to 1/4". Then 5/16", Then retap the hole.
Don't forget to use anti seize compound on the bolts when you reassemble so you never have this problem again.
F-body driver
Mar 6, 2023 11:44 AM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jlanz55
Sep 6, 2015 07:28 PM
85Special
Sep 3, 2015 04:21 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
