engine vibration, miss..............help please
Old Apr 5, 2001 | 07:40 PM
irocnroll89's Avatar
From: previously OKINAWA JAPAN,georgia, now new england
Car: 1989 IROC--1989 T/A
Engine: 5.7 TPI in both
Transmission: W/C T-5 in both
Axle/Gears: B/W 3.27 in both
well i have eliminated alot since the last time i have post about it. I know it is the engine not tranny or flex plate/torque converter. I have also changed the balancer, plugs, wires, distibutor. I checked timing and besides a little flux it is on 6 deg btc. The timing chain is 1 year old and a double roller. The compression on all is between 135-145 psi. I have tried to pull the inctectors to see if any of them drop more than the other, with little change. I need a direction before i tear into the motor. It has been suggested the one of the springs is toast or a bent push rods..... Please point me in the right direction thnx THE SHAGGY( THOUGH NOW DEFUNCT) IROC
'89 SHAGGY IROC
L98 7r4, all free stuff,T.E.S.,HOOKER CAT BACK,KYB,ACCEL8.8,JET fan sw. etc.
so much to do , so little money
[This message has been edited by irocnroll89 (edited April 29, 2001).]
Old Apr 5, 2001 | 08:00 PM
ede's Avatar
ede
no codes? i'd check fuel pump preasure and volumn, valve springs and push rods, and i'd leak it down.
ICON Motorsports
1st & 3rd
MM Black Diamond Lodge 538 F&AM
Old Apr 5, 2001 | 08:11 PM
i forgot , no codes. Also it smells really rich at the back. Oh and it only seem s to happen after the motor is at temp(185deg)thnx ede
Old Apr 6, 2001 | 12:40 AM
bttt
Old Apr 6, 2001 | 09:48 PM
Corry's Avatar
Car: 1987 Trans Am
Axle/Gears: 10 Bolt SLP Torsen, 3.73 ratio
Mine is acting similar, actually today I noticed it smelled like a lawn mower. It'll stall out while stopping, miss constantly, shake, etc. The thing is I already know what the prob w/ mine is. I have been b*tching and moaning about it for about a week now, my fuel pressure reg is blown. I don't have my pressure gauge down here, so I don't know what the pressure is at now, but when I left PA in january, it was running about 33 PSI or so. If it drops below I think 24, generally the car will not idle.
Now if the IRS will get me my check, I'll fix the thing!
Oh yeah, mine is throwing a code though, O2 sensor, and spark knock.
Corry Lazarowitz
clazarow@voicenet.com
clazarowitz@hotmail.com
SLP 1 3/4" headers, 3" cat back (stock cat )MSD ignition. MSD Blaster SS coil. More soon when funds are avail...
[This message has been edited by Corry (edited April 06, 2001).]
Old Apr 29, 2001 | 11:41 PM
back again, with an update........ I found out i had 4 bad fuel injectors. So that was the reason for the vibration at 1800 rpm. Now i have a vibration at 1600 rpm. The motor is smooth and the exhaust sounds very smooth, but in side the car the is a resonance. I also seem to have a vibration at 3000 and higher. Again this is all with the motor at temp. Also it is not the trans or T/C, as i have disconnected them and it is still there. I am wondering about fuel pressure? I have the 24 lbs SVO injectors set at 50 psi. Is this important? I don't seem to have any vacuum problems as i just put the whole intake and higher back toghether with new everthing.
'89 SHAGGY IROC
Old Apr 30, 2001 | 12:07 PM
BenIroc's Avatar
Irocnroll89 I think 50 psi is to much with
the 24 svo injectors. That kind of pressure
would be good for a supercharger or a very
very nasty 383 or 400 engine :-))
BenIroc
89 Iroc,TFS twisted,f*rd 9´´ rear etc etc
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
db057
Aug 22, 2015 08:17 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
