Code 15
Old Aug 19, 2004 | 07:13 PM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
Code 15
yeah... i just installed a comp cams 503 cam, 3000 stall converter, and hsr. when i started the car, had to adjust timing and fp, and all seemed well. well... took the car out for a spin and the ses light came on. paper clip trick showed a code 15. what causes a code 15, and how do i get rid of it? lol, thanks guys
Old Aug 19, 2004 | 07:23 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Code 15 coolant temp sensor- Low sensor fault
Old Aug 19, 2004 | 07:28 PM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
so do i have to replace the sensor? or what?
Old Aug 20, 2004 | 06:07 AM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
I would start With checking to see if there is a bad wire going to the sensor. and then Replace Sensor if neccesary.
The Sensor you are looking for is in the front of the intake
See Pic Below:
Left Pic 85-88 Intake Right 89-92 Intake
Note: (Left) Intake has a coolant temp(a) and a cold start sensor for the ninth injector.
The Right Intake only has the coolant temp sensor (a) for cold start and coolant temp for the computer
Old Aug 20, 2004 | 10:52 AM
dj haf's Avatar
Car: 1990 IROC-Z
Engine: 350 L98
my mechanic told me the sensor was fine but that the wires were burnt or something ... i have the HSR, so im assuming that the sensor is right under the tb on the intake manifold. ill check for any burns on the wires, but if the wires look fine, then maybe it's the sensor?
it's weird though... the car drives fine 99% of the time, and then all of a sudden, i feel something weird go through the car, i see the light, and then the car acts fine and the light goes away. weird huh? maybe that'll help diagnose my problem a little bit better
Old Aug 21, 2004 | 06:35 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
The wire is probably grounding out on something. Since its intermintant this may not be something youll be able to see very easily. Sensors dont usually go in and out of operation like that, so i would have to say it is fine.
89-IROCZ-5.0TPI
Feb 22, 2022 09:26 PM
Falcon50
Aug 22, 2020 03:26 PM
racereese
Oct 3, 2015 03:46 PM
Luigytico09
Oct 1, 2015 08:46 AM
dusterbd
Sep 29, 2015 08:40 AM
