fan will maintain but not drop the temp
Old May 1, 2001 | 12:13 AM
AustinT's Avatar
I Hooked up my Csi fan controller Gauge. Now I know exactly what temp the motor is running and what temp the fan will turn on. One problem is the fan will not drop the temp at all it will just maintain the temp and slowly let the car heat up. I didnt put the fan or radiatior on the guy befor me did. Its just a single fan with, with a 3 core radiator. What should I change to make it where it will drop the temp>
Old May 1, 2001 | 07:10 AM
82camaro's Avatar
Car: 82 camaro SC
What kind of fan do you have? It may be too small or worn out. Is the radiator clean(inside and out)? 50/50 antifreeze. What temp do you want to keep it at? How much timing are you running? Is this problem at idle or down the highway?
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
Bubbajones_ya
Jul 6, 2024 08:32 PM
my86bird
Oct 23, 2015 12:20 PM
86IROC112
Sep 11, 2015 04:04 PM
85Special
Sep 3, 2015 04:21 PM
