white smoke!!!
Old May 1, 2001 | 08:26 PM
Camrs89's Avatar
Car: 91 Formula, 79 Trans Am, 72 LeMans
Engine: 305 TPI, 6.6, 350 Pontiac
Transmission: T5, 3 speed, TH350
white smoke!!!
I was told that this is water or coolant leaking into the engine? How do i go about stopping this? And the cheapest way? Is this harming the car also?? thanks
http://www.fbody.com/members/Camrs89/
Old May 1, 2001 | 08:52 PM
Camrs89's Avatar
Is that what i have to fix is the head gaskets? is that how the fluid is leaking in? thanks
Old May 1, 2001 | 09:01 PM
Camrs89's Avatar
alright, thanks alot man. its gonna be a pain in the *** but if it helps...
Old May 1, 2001 | 10:15 PM
Vader's Avatar
89,
The Roadhead is probably right, but some other possibilities are a bad intake gasket near the coolant crossovers, a cracked head, cracked sleeve, or cracked TPI throttle body (water heated). Some older cars had failures of TVS sensors that would allow coolant through the vacuum lines and into the intake and chambers.
Start investigating before you start replacing.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old May 1, 2001 | 10:43 PM
Camrs89's Avatar
don't know if this makes any differance or not, but it's carbed, and the ehaust is not hooked up.
Old May 1, 2001 | 10:45 PM
Camrs89's Avatar
one more thing, what is the easiest way to see which thing is bad? is there some sort of way of testing it?
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
FormulasOnly
Jul 23, 2018 08:47 AM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Badass355ciz28
Sep 28, 2015 08:31 PM
