Keep failing Emissions for CO%.... Help...
Old Aug 25, 2004 | 08:52 PM
JerseyMark's Avatar
Car: 1991 RS Convertible
Engine: 96 LT1
Axle/Gears: 3.45 9-Bolt
Hey guys,
I brought my 91 RS Convertable to the inspection station today. It failed for the 2nd time. This time its CO's were at .89% when its not susposed to be any higher than .65% What would cause this to be high? I know the engine has some burnt up oil in it from when my brother owned it.. (When I did the timing chain, it was caked on the block & cover.) Anyway, what other kinds of things would cause me to fail in this test? See my sig for my mods.
Thanks,
Mark Balistreri
Old Aug 26, 2004 | 11:03 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
First thing i would do is remove the k*n for the test. Other than that co's are caused by anything that will make your car run rich. Could also be a pcv problem.
Old Aug 26, 2004 | 04:13 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Seems like I've already posted this answer once for you....
AIR Removed
The cat can't turn CO into CO2 without oxygen. It can't miracle up the necessary missing oxygen atoms out of nowhere. That's what the AIR system is there for.
Put your car back together right, it will sail right on through.
The schmutz in the crankcase has nothing to do with the issue at hand. Neither does the K&N. I'd leave those things alone and proceed directly to the root cause of the problem.
Old Aug 27, 2004 | 07:21 AM
JerseyMark's Avatar
Engine: 96 LT1
I hate when I bite myself in the A$$. I knew taking that AIR off would be a bad idea. Unfortuantely, since I threw away the AIR stuff... I guess I will have to buy a sticker.
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
6998poncho
Sep 25, 2015 02:56 PM
