weak engine
Old May 2, 2001 | 11:54 AM
blue91rs's Avatar
weak engine
my 91 305 TBI is real weak once the car warms up to operating temp. I've changed the plugs, the cap, rotor, air filter, oxygen sensor (bosch), the wires were ok. I also retourqed the TBI to intake bolts. My car can't even chirp em off the line anymore. Its a 91 camaro rs with 80,000 on it. Any suggestions? TIA
Old May 2, 2001 | 12:03 PM
Bort62's Avatar
I think the Main problem, Is its a TBI
60 Ranchero - Project ( Money Hole )
85 Sport Coupe LG4 - Daily Driver
Reader's ride -> My Ride
Just another Hot Rod kid, or thats what they all tell me.
Livin' the Stereotype
Old May 2, 2001 | 12:36 PM
blue91rs's Avatar
thanks, now try something I don't already know
Old May 2, 2001 | 12:45 PM
burnoutrpm's Avatar
if you want power dump the tbi ..trust me!!
89 firebird formula
360 10:1compression (350 .060 over)/fully balnced and blueprinted
comp cams xe262 cam
performer rpm intake/port matched to heads
#1407edlebrock 750
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner/cnc pocket ported
msd 6al/msd8.5 super condutor wires
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
griffin daul1" core rad.cutom fabrication to fit(but no cutting )
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
Old May 2, 2001 | 12:50 PM
Steve89GTA's Avatar
I you want power at any temp and want to run 10's all day...get a yamaha r1
Old May 2, 2001 | 02:42 PM
brharris27370's Avatar
Car: 91 Camaro RS Convertible
Engine: 385ci LT1 cnc ported heads big cam
Transmission: 4L60E automatic
Axle/Gears: 3.42 Zexel posi 7.5" rear
Mine is bad about starting off in 2nd gear after it warms up unless I am at a COMPLETE stop for several seconds. Pull shifter to Low 1 and see if that is your problem.
Old May 2, 2001 | 04:20 PM
blue91rs's Avatar
well, Its not starting in second, its just lacking alot of HP. The LO3 is rated at 170hp, but right now it feels more like a soft 120hp. It never used to be this weak, even 1000 miles a go it was strong. Has anyone ever used bosch O2 sensors before, any bad results? I saved the original, I'm thinking about putting that back in for $hits and giggles, I really can't think of any thing else. It doesn't set any codes, The intake is fine, WTF? I'm not looking for extra power, I just want what I had back.
Steve89gta, Don't like yahmaha, I'll stick with my VFR.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Reddeath210
Oct 6, 2015 08:20 AM
E Rod
Aug 28, 2015 05:17 AM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
