engine back together and running.. one question.
Old Aug 25, 2004 | 10:21 PM
JeffC1500TBI's Avatar
after the blown head gasket at 8000kms it's now put back together using felpro 1003 gaskets and gm intake gaskets. it's running but it was late when we finished so I'll have to wait t'ill tomorrow to do valve adjustments. should I let it run 15 mins before removing valve cover and adjusting?
valves aren't making any noticable noise but iff you put your hand on the pass side valve cover you can feel it. ds is ok. my cousing(he put the heads,intake on) and adjust valves as best he could to zero and told me I would have to have it running and loosen one at a time t'ill it ticks then slowly tighten t'ill it stops and give it an extra 1/2 turn(per edelbrock.)
Old Aug 26, 2004 | 11:00 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Try a search. There was recently a thread about the same subject along with many other threads on the subject.
db057
Aug 22, 2015 08:17 PM
jahblah
Aug 12, 2015 05:54 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
