Can't get the new mechanical fuel pump to go on!
Old Aug 26, 2004 | 12:16 PM
bulletboy29's Avatar
Car: '87 Camaro SC
Engine: 305 LG4
What am I doing wrong?
Old Aug 26, 2004 | 12:21 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Probably you're not raising the rod that drives it, back up out of the way.
When you remove the old pump, the rod usually falls down out of its little passage. Then when you try to put the new pump on, the finger hits it, instead of going up under the end of it, like it's supposed to.
Push it as far back up in its passage as you can, and try to put the pump on. If the rod continues to slide down, take out the top bolt that holds the smog pump bracket on; and get a much longer bolt, like 1½" long or more; push the rod up with one hand; and run the longer bolt into that hole FINGER TIGHT. The bolt hole goes right into that passage, and the bolt will capture the rod and hold it up against the cam eccentric. Make sure you take the long bolt out and put the right bolt back in after you get the pump on, with a little bit of sealer on its threads.
Old Aug 26, 2004 | 12:25 PM
Car: '87 Camaro SC
Engine: 305 LG4
alright...let me go back out there and see what i can do.
Old Aug 26, 2004 | 12:32 PM
Car: '87 Camaro SC
Engine: 305 LG4
I got it!!! It wouldn't budge at first, it acted like it was stuck. I appreciate it!!! Now let me go hook up the fuel lines and maybe tear some other stuff up. Thanks!!!
Old Aug 26, 2004 | 12:33 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Old Aug 26, 2004 | 12:43 PM
88Camaro350's Avatar
Car: 2002 Formula Firebird
Transmission: 4l60e
Must be nice being able to use a mechanical pump. I wish I could. I have no place in my block for it at all.
Old Aug 27, 2004 | 10:56 AM
BIGJON's Avatar
Car: 1989 Formula 350 Firebird
Transmission: 700 R4
That smog pump bolt you are talking about somehow stripped out and fell out.........seems it leaked oil like CRAZY when I came to a stop.....the oil rushing forward was coming out I am assuming...is this why there is even access for oil to come out?? I guess my thought was that why would a bolt hole with a bolt in it basically stop oil from coming out?? I know that bolts aren't meant to seal at all..........is there a way to go about fixing this?? I deleted the smog pump when the bolt came out.....now I just have one very lightly threaded in since it is stripped.......should I coat the bolt with RTV and see how it seals?? You have any ideas?? Don't mean to steal the topic but this relates to an issue of mine....thanx
Old Aug 27, 2004 | 11:01 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
The bolt hole you refer to, assuming it's the same as the one I've circled below needs to be plugged. Left unplugged, it peers right into the carankcase.
Try tapping it to the next larger size.
Old Aug 27, 2004 | 11:03 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
I'd try just spooging the hell out of a SHORT bolt and run it in there finger-tight.
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
gta90
Sep 15, 2015 04:00 PM
justin57
Aug 20, 2015 07:05 PM
