Ticking Noise
Old Aug 29, 2004 | 12:24 AM
cyipher's Avatar
Car: 1984 Pontiac Trans Am
Engine: 305 SBC
Transmission: Automatic
Ticking Noise
I have a ticking nosie coming from my computer controlled carb, is this normal? I can make it stop by pulling the connector from the carb, but this also sets a ses light. Any clues on what this might be? could this also cause my car to diesiel, because im having that problem too?
Old Aug 29, 2004 | 01:50 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
If the engine is off, does the ticking stop about 20 seconds after ignition is turned on? If so, then it's the mixture control solenoid.
Dieseling can be blamed on a fwe things. The first thing to check is your timing. Another thing is, what is the idle speed in park? If it is too high, your engine can also diesel. Those are the 2 more common things.
Old Aug 29, 2004 | 12:22 PM
cyipher's Avatar
Engine: 305 SBC
my idle is about 1500 is that high, hahaha. now how do i turn it down...?
Old Aug 29, 2004 | 12:24 PM
cyipher's Avatar
Engine: 305 SBC
also i know on s10s where most of my experence is, that you have to disconnect the computer to time the car, is it the same on firebirds?
sleprock
Interior Parts Wanted
Oct 3, 2015 11:01 PM
sjorgens
Oct 1, 2015 07:54 PM
meeklay812
Oct 1, 2015 03:46 PM
david068513
Sep 13, 2015 11:24 AM
david068513
South East Region
