Small Block Cylinder Heads ???
Old Aug 30, 2004 | 09:31 PM
rustyZ28's Avatar
Car: 87 Z28
Transmission: 350 Turbo
I just bought a set of heads at a swap meet of a 325hp 327, the casting number on the are 3782461X can anyone tell me if these would be a good set of heads to have redone. The are doulble camels with no assesory holes any hel is greatly apppreciated.
Old Aug 30, 2004 | 09:48 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
You will run into some problems when you try to bolt up your accesorys. They were pretty good heads for the time but head technology has come a long way since then. Youd probably be better off starting with a newer head like the vortecs and getting those reworked.
Old Aug 30, 2004 | 09:58 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Sell them to some moron doing a resto.
Old Aug 31, 2004 | 08:38 AM
AJ_92RS's Avatar
Car: yy wife, crazy.
Engine: 350, Vortecs, 650DP
Transmission: TH-350
Axle/Gears: 8.5", 3.42
And why does this person have to be a "moron"?
Old Aug 31, 2004 | 10:00 AM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
Aside from the moron term, you'd be ahead of the game selling them. Waay back when they were a great head-when compared to what they had waay bacak then, but as stated above- we've come a long way baby!!
So for sake of sanity of bolting everything back upto the motor acc. wise and a much better performance, lose the fuelie heads and get a newer casting. Nothing wrong with double humps as they can make good power with modifications, but with the mods to get them to be worth a chit, your money ahead buying a new set of vortecs that are more effiecent and flow better. Or if you have the coin any of the Dart, AFR, Brodix, Trick Flow, Motown, etc...will easily be better than the camel backs.
theshackle
Mar 5, 2017 06:37 PM
Mickeyruder
Sep 2, 2015 02:45 PM
camaro71633
Sep 1, 2015 10:24 AM
NinjaNife
Aug 23, 2015 11:49 AM
theurge
Aug 21, 2015 12:46 PM
