What is this....
Old Aug 31, 2004 | 06:16 PM
88Z's Avatar
88Z
Car: 88 Iroc
What is this....
What is this gold canister looking thing that screws into the back of the block, right behind the intake manifold? I'm swapping an L98 for my LB9. It actually came off the LB9, but the L98 doesn't even seem to have it. The threads are plugged, so I'm wondering if it's totally necessary. Also, what screws into that little notch in the oil pan? I can't remember what sensor or whatever screwed in there.
Old Aug 31, 2004 | 08:49 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
If it looks like a bell-type thing, with 1, 2, or 3 wires coming off of it, tees into the rear china wall, and would sit right behind the distributor, it is the oil pressure sender/switch (depending on application).
Old Aug 31, 2004 | 08:59 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
sounds like an oil pressure sending unit to me.... did the oil pressure gauge work in your car before the swap? if not id bet thats what it is... if thats what it is then u dont realy need it but you wont have a working il pressure gauge.
GTAman
Jul 3, 2024 07:29 PM
luvofjah
Sep 26, 2015 08:28 PM
gusman
May 27, 2004 12:07 PM
PMGCamaro
May 13, 2004 07:15 PM
Street Lethal
Sep 14, 2003 01:54 PM
