Rockers for Vortec Heads
Old May 3, 2001 | 01:28 PM
wiggy'sIROC's Avatar
Car: 1986 IROC
Engine: 305 going to 355
Do you have to use "Guided or self aligning" rockers on Vortec heads or can you use guide plates and regular rockers?
Mark
1986 IROC LG4 "Bone Stock" (for now)
Old May 3, 2001 | 02:44 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If you don't use self-aligning rockers, you have to replace the press-in studs with screw-ins made for the guide plates. Machining required.
Old May 3, 2001 | 03:05 PM
Car: 1986 IROC
Thanks Five7!!! Any Idea what that machining process costs?
Old May 3, 2001 | 03:26 PM
jaretz28's Avatar
Cannot be more than about 50 -75 bucks a head. Not that much machining requuired
Old May 3, 2001 | 07:21 PM
five7kid's Avatar
After all the press-in studs are removed, the bosses will be milled to obtain a flat surface. Then, each hole will be tapped out.
How much, I don't know. Probably in the range jaretz28 estimated - you need to call. If you are putting them on your 305, you'll need them milled about .045 to bring down the chamber volume to keep compression up - the intake will need to be shaved as well to allow it to align back up to the ports. Add that to the price estimate (about $40-60/head, I'd guess).
I'd highly recommend you reconsider the Vortecs. For the same money, you could get World S/R Torquers that have screw-in studs, don't need guide plates or self aligning rockers, and a standard intake will bolt to them. They flow about the same as Vortecs. They also have the exhaust cross-over passage so your EGR will work - Vortecs don't.
Old May 3, 2001 | 08:35 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
The vortecs require self aligning rockers if you don't have guide plates.
Old May 4, 2001 | 09:23 AM
Car: 1986 IROC
I'm sorry, I guess I should have mentioned that the heads will be going on a 355 that I am building to replace my LG4. Do the SR Torquers really flow as well as the Vortecs? If SR Torquers will make the same power as the Vortecs I will go with them so I wont have to buy new rockers, intake, valve covers and such. There are so many options as far as heads go, I will take all of the input I can get. Thanks!
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
earlpote
Aug 28, 2015 10:42 AM
L98GTA87
Aug 11, 2015 06:55 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
