setting timing questions for vac advance
Old May 8, 2001 | 09:05 PM
84CAMAROHIGHOUTPUT's Avatar
ok here we go, my distributor should be here tommorrow and i need to get my engine running
(been working on this for a month). I have a timing light and know basically what to do with it, my engine is supposed to be set at 6 BTDC, currently at 0 (just adjusted valve lash)When I start my engine is the mark on the harmonic balancer supposed to line up with the 6 on the timing mark constantly as it rotates? Is that the purpose of the light to see the marking line up? And as far as advancing the timing at the timing mark I would turn the distributor counter clockwise, correct? Also I would need to rotate the crankshaft one more time to 0 before installing the distributor for the number one piston to be at TDC and install it with the rotor pointed between the 1 and 8 terminals on the distributor cap, correct? let me know if i'm missing anything yet, i want this car running tommorrow!!!!! thanks in advance
Frozer!!!
Jan 19, 2024 04:55 PM
specialized
Jun 18, 2022 09:26 AM
Vintageracer
Jan 10, 2020 05:33 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
