How do I tell If it is a Coolent leak?
Old May 8, 2001 | 10:32 PM
CAMARO82's Avatar
How can I tell if it is a coolent leak? At stop lights I see white smoke coming from my exaust. It smokes alot! I changed my oil last week and I checked it this morning and it is full. What Can I do?
Old May 8, 2001 | 10:37 PM
camaro1j's Avatar
Car: 92 Camaro
Engine: 406 sbc
Axle/Gears: 9" ME with 4.56 gears
This is a problem with third gens. Thats all you have to change your valve cover gaskets.
84 Z28
406
accel supper ram
6000 rpm Hyd roller cam
afr heads
t-56 trans
9" ME rearend 3.91 Gears
Old May 8, 2001 | 10:44 PM
JoeIROC's Avatar
I dont see how that can be even related to valve cover gaskets! Head gaskets, maybe...
Are you losing coolant or oil? Check your levels, and then again 1 week later. One of those will be lower. Then you have the culprit. There are many causes, too many to list, but most commons:
coolant: head gasket problem.
oil: valve SEAL problem. Not a valve cover gasket.
You might have smoke coming from the engine if it were a valve cover gasket problem. That would be due to oil coming out through the valve cover and burning up from the exhaust heat or something.
86 IROC TPI 305
700-R4
K&N Air filters
Dyno-Max cat-back
Summit tranny cooler
CEI throttle enhancer chip
Trans-go shift kit
RS Reaper
Oct 17, 2018 07:52 PM
Mark_ZZ3
May 24, 2018 01:02 PM
Reid Fleming
Oct 10, 2015 09:56 PM
aaron7
Sep 30, 2015 09:15 AM
mfp189
Sep 27, 2015 09:25 AM
