firing order/distributor question
Old May 9, 2001 | 04:24 PM
ajohnson's Avatar
I removed all the plugs off the distributor at the same time, without marking them. Now I know which ones are which but I don't know where to put each one on the distributor. I know the firing order, but which terminal is #1 and which direction does the firing order go, clockwise or counter??? Please Help!!!
I have a '90 Camaro RS with 305TBI engine code E. Some Help me please!!
'90 RS 305 TBI 700r4
plans for an LT1 with a T56 6speed
Energy suspension
sway bars
kyb shocks
jet chip
stainless Borla exhaust with no cats
Old May 9, 2001 | 04:36 PM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
If you cant remember where ANY wires were connected to the distributor then you will probably have to rotate the crank and re-do the wires. If you can remember where at least 2 wires went you could probably figure out where the rest go by following the firing order....which runs clockwise
I assume you did not remove the distributor from the engine. If you did without marking the rotor, then your only option is the first one I mentioned.
92 Camaro RS, LO3, 5-spd, T-tops
Performance:
K&N Open Air Filter, Edelbrock performer TBI intake, Fastchip Prom, Timing +4 degrees, Centerforce clutch, Xact 8mm wires, SLP 1 3/4" Headers (coated), Flowmaster Catback Exhaust, Z28 Grille w/aftmkt fog lamps
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, 3.42 gears w/Torsen posi
Old May 9, 2001 | 04:42 PM
Ed Maher's Avatar
Car: 04 GTO
Transmission: M12 T56
Well, if you're lucky, #1 will be the one that is on the frontest (lol, good word, eh?) DS of the cap. Usually thats where they end up factory. If the engine has been apart, it could be anywhere.
I'd try that spot first, cuz you can't realy hurt anything if you're putting the wires on retarded one position (it'll fire on the exhaust stroke, might make noise, won't hurt anything), and i really doubt #1 is coming off the front PS.
...ed
Ed Maher - Moderator @ The Carb Board
92 Z28 Convertible - Quasar blue / Tan top
LB9 4L60 GU2 G80 - stock, soon to be sleeper
-=ICON Motorsports=-
- Definitely prototypes, high powered mutants of some kind. Too weird to live, too cool to die
92camaroJoe
Jul 29, 2023 07:57 PM
86IROC112
Aug 21, 2015 07:20 PM
TheExaminer
Aug 19, 2015 10:07 PM
redmaroz
Aug 16, 2015 11:40 PM
92camaroJoe
Aug 13, 2015 06:07 AM
