distributer gear?
Old Sep 9, 2004 | 02:51 PM
btcamaro's Avatar
Car: 91 Camaro
Engine: 383
distributer gear?
I have broken the distibuter gear twice in the last 2 weeks. My ? is what would be causing this to happen both times it happened while cruising down the street wasn't even under a load or high rpm. I don't understand what would cause this to happen
Thanks,
Bryan
Old Sep 9, 2004 | 03:04 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Foreign matter in the oil; jamming the oil pump gear teeth.
Old Sep 10, 2004 | 10:09 PM
btcamaro's Avatar
Car: 91 Camaro
Engine: 383
well I pulled the motor out tonight to take a look at what happened to it and found that the pickup screen had broken off at the end of the tube. The oil pump had sucked up some junk from the bottom of the pan and jammed up. Guess it is time to rebuild.
Old Sep 10, 2004 | 10:55 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Rebuild what? The pump or the engine? Oil pumps are cheap enough that you should just replace the pump.
Melling M55 and a 55-s pickup. Mr. Gasket #26 pressure spring, too, if you can.
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
georgiaslim45
Sep 9, 2015 08:12 PM
georgiaslim45
Sep 9, 2015 08:11 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
