Wheel Wobble??
Old Sep 9, 2004 | 06:39 PM
86'Bowtie's Avatar
Car: Hugger Orange Camaro
Wheel Wobble??
Just recently I ended up losing control of my car, swung sideways
and jumped a curb: causing my aluminum rim to bend, but left the tire inflated. I went ahead and ordered the exact same rim, mounted the rim and now the wheel(driver's side rear)wobbles.
What could be the problem?What am I to look for?damage-wise?
The tire and rim have been mounted,balanced,etc.
Just wobbles when in motion.DUECE
Old Sep 9, 2004 | 06:58 PM
z28monster's Avatar
Car: 86 IROC-Z
Axle/Gears: 3.42s/posi/disc
you prolly have a bent axel now... sorry to say it man but im almost definate thats what your problem is.
Old Sep 9, 2004 | 07:21 PM
86'Bowtie's Avatar
how do you fix it?ways to bend it back perhaps?
Old Sep 9, 2004 | 07:27 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Replace it.
colonboy14's Avatar
Car: Trans Am
Buy new ones. It wouldn't be safe or practical to try and bend the axles back, they're like rock hard.
Old Sep 9, 2004 | 07:28 PM
slayer2000's Avatar
Car: 1990 GTA
Transmission: manual/t56
you should just replace the axle shaft with a new or good used one.
Old Sep 9, 2004 | 07:59 PM
86'Bowtie's Avatar
how much do the axel shafts run for? I only need one.
how hard is it to replace?DUECE
Old Sep 10, 2004 | 03:15 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
You could probably get one (or a trash rear end) from a junk yard for not too much. The ones you have should be 26 spline shafts so make sure to get the same ones. Just replacing the axle isnt too bad. The only kind of hard thing is getting the pinion shaft bolt out. On mine (and probably all the rest of them) that thing was tight. Took some banging with a mallot to break it loose.
EDIT: Its advisable to replace the axle bearings and seals as well while you have it apart, but its more work.
Old Sep 10, 2004 | 07:33 AM
86'Bowtie's Avatar
Thanks for all the info guys.DUECE
Old Sep 10, 2004 | 09:01 AM
a73camaro's Avatar
Make sure that the rim is true first. Also check where the wheel bolts againts the axle fange and make sure it is clean.
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
Saxondale
Sep 15, 2015 06:42 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
FormulasOnly
Sep 6, 2015 10:42 AM
