what to do with distributor ? and electronic choke q ,,,
Old May 8, 2001 | 10:51 PM
91camaroRS's Avatar
i got a blueprint accel distributor and it has a black wire and a white one going into each other where does that sopose to go and does anybody know what wire to use for the electronic choke ?? by that i mean the positive one ?
350 bored 30 over ..882 casting heads ..comp cam..hooker headers.. 700r4 corvette servo .. 3.73 and SLP posi no hood on the car , holley 750 CFM, performer RPM intake.. and umm couple other things here and there
Old May 9, 2001 | 10:26 AM
Damon's Avatar
Can't help with the distributor but the electric choke on the carb should be hooked to an convenient 12V source of ignition-switched power. That is to say, when the key is in the run position it should supply power to the choke. Don't forget to run the other terminal (if the choke has 2 terminals) to a convenient ground (like the body of the carb itself)
Old May 10, 2001 | 12:47 AM
91camaroRS's Avatar
can somebody please help with the distributor i would like to start my car ............please ??
Fanatic1074
Oct 3, 2022 05:57 AM
InfernalVortex
Apr 20, 2021 11:31 AM
RedLeader289
May 28, 2019 01:47 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Damon
Sep 26, 2015 04:29 PM
