Having Trouble with Head lights.
Old May 9, 2001 | 09:04 AM
brockrodgers's Avatar
Car: YTG Camaro
Engine: 383
Transmission: TH-350
My passenger side head lights are not working correctly. When they are on high beam they are working correctly, 1 light on / side. When off high beam the passenger side both lights stay on but only have the intensity. I tried changing the headlight but that did not correct the problem. I also checked the fuses and they seem to be fine.
My gut feal is that there is possibility a short somewhere but I was hoping somebody else had ran into this before and could help me trouble shoot the problem.
'84 Camaro w/ Large Jouranl 327 bored .030 over; 3.73 geared Auburn Limited Slip Diff. FlowMaster Muffler w/ Shortie Headers. TH-350 Built Trany Underneath B Mega-Shifter. Many Engine compartment Dress Up Mods. Edelbrock High Flow Water Pump w/ Flex-a-Lite Cooling Fan.
Work in progress is Sponh Torque Arm. It is still under construction @ www.chartermi.net~brodgers
Old May 9, 2001 | 10:07 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The ground wire from the headlight sockets for that side is broken.
ICON Motorsports
Old May 10, 2001 | 06:18 AM
Car: YTG Camaro
Engine: 383
I tried to determine if there were any loose ground wires and could not find any. I also noticed that all of the original protective coating is still in place around the wires so I am doubtfull that there could be a short along the wire.
I did notice that I mis-spoke when explaining the problem. The real problem is that the lights work when they are on low beam but when switched to high beam, the Passenger side, outside light, does not stay on.
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Sep 2, 2015 10:59 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
stalkier
Aug 21, 2015 01:54 AM
