hydraulic lifters - is this normal?
Old Sep 13, 2004 | 10:49 PM
cormyr's Avatar
Car: 89 Formula 350 WS6
Engine: 383 miniram
ok, so i'm putting together the new 383 and i went to check the piston-to-valve clearance using the modeling clay method when i noticed that the stock hydraulic lifters im reusing squashed down under the pressure of the valve springs as i turned through a cycle. now, since i only installed one head to do this test, i checked the other 8 lifters that i haven't yet installed and they are very firm and can't be compressed by just using a pushrod. all but one of the ones i did install can now easily be compressed with a pushrod. the plunger returns to normal after pressure is released so the springs inside the lifter seem to be working and everything else about them looks perfect. i'm just wondering, is this normal or does this mean my lifters are collapsing under the increased pressure of the double valve springs on my new heads? or is something else wrong here? will the lifters pump up to normal after the engine is started? i checked the lift with a dial indicator and it looks like im only getting about half the amount of lift that im supposed to have, except on one valve which appears correct, thats the one that didnt compress. i'm a bit confused...
Old Sep 13, 2004 | 10:54 PM
laiky's Avatar
you should be using checking springs and preferably a solid lifter
Old Sep 13, 2004 | 11:16 PM
KrisW's Avatar
Car: 88 V6 'bird/89TBI bird/85 T/A
Engine: 2.8/TBI/TPI
Transmission: V8 T-5/700R4 x2
Axle/Gears: 3.42 open/2.73 open/ 3.27 9 bolt
your lifters will all perform near the one that didn't compress when the engine is running. Hydraulic pressure keeps applied from your oiling system so that they can't collapse. You will bend valves or pushrods before you collapse a lifter most of the time if your engine is running.
Old Sep 14, 2004 | 12:35 AM
cormyr's Avatar
Engine: 383 miniram
so is this ok then for hydraulic lifters? should i not be concerned?
Old Sep 14, 2004 | 01:30 AM
KrisW's Avatar
Engine: 2.8/TBI/TPI
Its ok for hydraulic lifters to collapse when you're doing what you're doing. You should always use solid lifters for checking tolerances.
Old Sep 14, 2004 | 11:31 AM
cormyr's Avatar
Engine: 383 miniram
oh yeah i forgot that trick. thanks.
Fanatic1074
Oct 3, 2022 05:57 AM
skinny z
Oct 5, 2015 06:23 PM
Linson
Oct 1, 2015 09:50 PM
dusterbd
Sep 29, 2015 08:40 AM
mfp189
Sep 27, 2015 09:25 AM
