wiring harness
Old May 11, 2001 | 10:34 AM
92RS shearn's Avatar
Car: 92' RS
Engine: LO3
Transmission: Probuilt 700R4
Axle/Gears: 3.70 9-bolt
wiring harness
I bought a TPI system of a friend of mine off an '87 IROC. I need a wiring harness. What is a good company that make wiring harnesses? One where I will keep all of my dash functions and all.
Painless wiring? others?
Looking to put the TPI in soon so I need the harness.
Flowmaster,Edelbrock open filliment filter with K&N filter in it
160 stat,
Old May 11, 2001 | 10:39 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Well first I would check the local junk yards, but chances are slim that there are any L98's in there. I have heard that painless wiring is good, and easy to install. But it will probably cost you a couple hundred bux...
1983 Firebird
TH700R4 Auto
Small Block 400
LG4 ECM, Intake, Carb, Distributor, etc.
Soon to be non-computer.
Clarion Head Unit 45X4
2 Pioneer 400W 12" Subs
Third Gen Performance
"A four cylinder is half an engine."
bottledpower's Avatar
Car: 85 IROC
Transmission: 700 r4
ive heard a lot of good things about painless wiring harnesses, but i havent actually used one. so i guess your best bet would be to contact a dealer such as summit or jegs and ask them if your accessories are compatable. might need a fuel pump upgrade to run the pressure required for TPI also. good luck.
85 IROC 350 11:1keith blacks,.555lift erson roller cam,1.5 crane roller rockers,edelbrock intake,holley 4150 750dbl pumper, nitrous oxide,full length heddman headers,true dual exhaust, 11"stall converter, 700R4, 3.73 locker
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
stalkier
Dec 6, 2015 11:25 PM
g.l.mos
Aug 22, 2015 12:02 AM
stalkier
Aug 21, 2015 01:54 AM
