tripometer won't reset
Old Sep 15, 2004 | 01:02 PM
Maverick_82's Avatar
Car: '82 trans am (w/ t-top)
Engine: 5.0L 305 H
Transmission: automatic
My tripometer wont reset. I tried fidgeting with the reset **** but nothing happens. The **** shows alot of wear n' tear, it resembles a striped screw head. Any help would be appreciated, Thanks.
Old Sep 15, 2004 | 04:40 PM
Damon's Avatar
You ain't gonna like it, but the answer is a new gague cluster. When mine failed there were little plastic support pieces inside the odo that broke and prevented it from resetting- stuff could more around in there in unnatural ways). No way to fix it but a new gague cluster in my case. Or you could crack it open and maybe see if you can crazy-glue stuff back in place to get it working. I personally took one look at it (after ripping into it) and said "forget it" and bought a new cluster.
Old Sep 15, 2004 | 05:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
If the trip odometer shaft is floating around because the plastic J-hooks broke off, you can wire the axle down.
Do a search, it was discussed a couple of months ago.
Old Sep 15, 2004 | 05:51 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
The following link may be helpful:
https://www.thirdgen.org/techbb2/sho...hreadid=249244
JamesC
Ed1LE
Sep 30, 2018 09:14 AM
Bubbajones_ya
Oct 25, 2015 08:01 PM
okfoz
Oct 13, 2015 02:19 PM
Luigytico09
Oct 1, 2015 08:46 AM
the_hamturdler
Sep 30, 2015 12:50 PM
